New Air 2S pilot in SoCal Desert
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
scheduled for the Part 107 test on Wednesday
Just a quick posting based on your remark, do you qualify?
rand new Air 2S owner coming to you from the low desert of sunny Southern California. This is my first drone with about 3 flying hours under my belt and scheduled for the Part 107 test on Wednesday.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Even in California, there are a couple of Legal Things you may need to do…
Until you receive your Pat 107 and Good Luck with that (be sure to let us know how that goes…), you still need your TRUST Certificate. It's a lot cheaper than the 107 license…
Your Drone weighs more than 250-grams (0.55 pounds) and even if you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams… But not for you…)
Since you live in California, there are specific laws and rules for you to follow, please check to ensure these are current.
Since this is your first drone, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: Gagey52
Welcome to the forum! :)
Reactions: GFields and MA2 317
Thank you for all the information!
I am TRUST certified which I did before registering my drone with the FAA and before my first flight.
I live in a rural area on 5 acres where I have plenty of space to practice without having to worry about other people being around and possibly injured. This has helped me build confidence in controlling my drone.
I did complete the Pilot Institute 107 and Drone Launch Academy 107 courses. Both were well done and I fully recommend either or both.
Greg
PS - Thank you to all for the warm welcome!
Reactions: LoudThunder
InspectorTom
