New pilot in West Cumbria UK
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hi everyone, I'm 69 and have just purchased my first drone, the Mavic mini 2. Thank goodness for YouTube videos. I have 1 week to learn as much as possible before I have 4 days holiday in the Lake District UK.
Hello from the crossroads of America Wallaseyman.
Good luck on your future flights and welcome to the Forum. :cool:
Greetings from Birmingham Alabama, welcome to the forum!​
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Below is the link to all of the downloads offered by DJI for the Mini SE. You will also find the 47-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini SE - Download Center - DJI
Happy Droning
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. Read what I wrote to Mark Regan who was the Original Poster (OP).
Below are is the download for your Drone's manual. Read it, then re-read it… you will not be unhappy that you know so much about your new "baby"
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Download Center - DJI
Happy Droning
Reactions: Skywatcher2001
Welcome to the forum! :)
Kia-6098.111
