New to DJI NOT to drones!
banglaman
Portland OR
Hello Experts,
I've been doing RC planes since 1988 but ALL of my projects are hand built and even sometime controls and engines and circuits firmwares the whole shibang. Building drones since 2014 However I'm new to DJI and have a lot to learn. I just got a DJI Air 2 (not the 2S).
Please guide to the threads for it. I'm interested in software mods repairs part etc. I'm don't have any commercial interest of ANY kind. Just have fun, learn and share (FLS) :)
Thanks -- Asif
Hello from the Crossroads of America banglaman.
Nice to meet you Asif. 🤝
Welcome to the Forum. :cool:
Welcome to the forum! :)
Hello from Vero Beach Florida and welcome to our Forum. There is a ton of great information here.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Fly On and Fly Safe…
xa_
