New to drones
jlynde
Missouri
Hi, my name is Jeff and I am working on becoming a drone pilot for my local park and rec here in Missouri. I am considering going between the DJI Mini 3 Pro and the DJI Air 2s. I would like to hear what everyone suggests and why. I would also like to know if anyone has had success with any particular prop guards.
Thanks!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello from the Crossroads of America jlynde
Nice to meet you Jeff. 🤝
So I assume you are working on the Part 107 certificate that will allow you to work for the city.
And you probably know about the TRUST test you should take anytime and keep a copy with you when you fly.
If not, here's a few links to get you going. :)
Good luck and welcome to the Forum. :cool:
I used the stock DJI prop guards for my Spark 90 percent of the time and purchased the stock guards from DJI for the MA2.
I don't use them as often but they are nice to have.
I use them if I suspect birds in the area as it makes the aircraft easier to see and it appears larger that may intimidate the birds to stay away from a potential prop strike.
And if your hands are full, you can carry the aircraft with your pinky finger. :D
Greetings from Birmingham Alabama, welcome to the forum!
I use the Air 2s with prop guards.
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Hey Jeff,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
One of our members, MA2 317, has already given you Great Advice and now it's all on you. The TRUST Certificate is easy to get and get early, you do not need to own a Drone to acquire the Certificate…
Since you live in Missouri, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you expressed interest in both the DJI Mini 3 Pro and the DJI Air 2s, I've provided the links to all of the downloads offered by DJI for both Drones, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy, Safe and Legal Droning…
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome to the forum! :)
Welcome to the forum from the outback of Australia. I can’t help you drone wise as I own neither of the two your looking at. First question I’d ask is what will you be doing with the drone? Is that the best drone for your task etc
Regards
Pleopard
