New to forum from austin
Big Ransom Studio
Austin Metro Area
Hello. I’m new to the forum and hope to learn, and gain valuable insight, tips, hacks, and mostly your tried-and-true wisdom and experience.
Thank you in advance for any help or time you spend for me. I know your schedules are likely much heavier than mine, and I truly appreciate it.
Off to the races…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Off to the races…
welcome. happy to have u join us
Welcome to the forum! :)
Off to the races…
Welcome, I'm from Austint too!
UR7CR
