- Joined
- Sep 9, 2018
- Messages
- 36
- Reactions
- 9
- Age
- 49
Too bad the Mini 3 Pro doesn't have tripod mode as I find Cine mode still too fast. Can someone point me to a place where someone posted some nice smooth gimbal settings?
The “DJI Fly” app on any remote, the RC (with the screen) or the app on your device.Hello
what remote control are you talking about?
Thanks I will try this. Does this affect all stick controls and the gimbal or do I have to change the gimbal speed settings too?Have you played with the control curves yet? You should be able to bend them into something very, very slow.
Hit the 3 dots in the upper right corner, tap"control", go down to the Remote Controller section, look for Advanced, tap it. There will be 3 x/y graphs that show the response curves. You can bend them with your finger, or enter values. Low values make the low-speed control range larger, high values make it smaller. Try .1 for Cine mode, see if you like it.
Video shows "unavailable - private". Just change to "unlisted".A lot depends on the subject matter, the frame rate, the subject distance and the flight path relative to it.
Here's a worst case scenario. Highly detailed subject matter, travelling laterally, as close to the subject as I felt comfortable and flying as slowly as I could while maintaining an absolutely constant speed. Still too fast IMHO.
Showed up as "Draft" in YT studio. Should be fixed now.Video shows "unavailable - private". Just change to "unlisted".
^^^. Yup, 1mph or less, no problem. And try slomo.Turn the expo as low as you can. Adjust the pitch and yaw just a little faster than you like. Then with a very little stick movement, you can easily go 1 mph.
Still no,^^^. Yup, 1mph or less, no problem. And try slomo.
