Now that Art is gone what Setting is best?
Can you not go into DJI Go app which I think still has art, select art
Then
Open DJI Go4 and it will transfer over.
Now
If you change to something else in DJI Go4 art will be gone so you would need to go back into DJI Go app an do over again
Then
Now
This work around is no longer needed. DJI GO4 has Art again
Reactions: razors
What are the best settings in Art for contrast, saturation and sharpening?
Ground Control have a free LUT intended to use with -1, -3, -3
I don't much like results with it, to be honest.
Art is pretty flat all on default - you will still need some adjustment most times, or try all -1.
There is no one 'best' setting, just see what works in different light with your editing options.
Reactions: Nigpd
Agreed with the above.
The settings I like are -1 -2 -2 for grading in DaVinci Resolve 12.5.
I stick with -1,0,0
The bit rate and codec are too limited to benefit from reducing contrast any more in hopes of maximizing dynamic range. Art is flat enough for the purposes of matching similar flat media and grading. I also slightly overexposed by 1-2stops to minimize artifacts on the low range (shadows). This has served me well since early days with P3P. It's a little counter to normal cameras, but it is what it is
Sent from my iPhone using Tapatalk
SK farming
