Huge difference. The gust ended up eating most of the battery though.Good job! Your latest attempt has been updated. Flying over water away from interference definitely makes a difference.
Thanks for updating
Nice run, really impressive! Leaderboard updated!My screenshoot ;-) got back with 19%
What is the optimal height (altitude) to fly at when doing range tests?
insane..!!!@Long Ranger
A bit further....still not 6k[emoji42][emoji42]
View attachment 34621View attachment 34622
Finally crossed the 5000feet mark! It took some time, but the Mavic air gave me the confidence to go that far. I know that I could have pushed a bit more, but it is my first time flying that far. I didn’t want to push my luck and the post that I lost my drone
P.S had to replace the screenshots, the resolution was bad.
@Long RangerView attachment 34843 View attachment 34844 Just did this run with the ThreeKing Parabolics. Landed with 30% battery but because I was next to my house the interference cut this run short. It was done it 5.8ghz, which after one final test (this) proved itself to be wayyy better than 2.4ghz. I will most definitely try a battery mod when (more like if) it becomes available.
Nice run for Parabolics! You are in 6th position on the mods board.
Yeah and conditions were no where close to ideal. 10 mph winds and strong interference from my house, I need to boost now because after flying in another location I normally do, I could only reach about 4500ftNice run for Parabolics! You are in 6th position on the mods board.
Thanks andYeah and conditions were no where close to ideal. 10 mph winds and strong interference from my house, I need to boost now because after flying in another location I normally do, I could only reach about 4500ft
View attachment 34918 View attachment 34919Can’t say I didn’t try. Lost about 15mph speed on the way back and forced me into landing. What amazes me is that I still had 57% battery so I could have exceeded 18000ft probably and made it home if their was no wind. Landed about 7500ft out.
would have made it back if there were not 15mph windsGreat run!! You will get there if you keep pushing like this[emoji106][emoji106]
