"Pan blur"
Rabber
Murrieta, CA
How can I reduce "pan blur". I am shooting HDR 30 fps. It seems no matter how slow I pan, I still get some blur. ??
What are you flying?
increase the frame rate
still, the closer an object is to the lens, the more motion blur.
It maybe normal. Can you post some sample footage? Here's a vid I did in HDR mode on a MA2.
Need to know more - like are you doing it in Tripod / Normal / or Sport mode on the controller? Also you can change your YAW / Gimbal settings in FlyApp to slow down movements in any of the 3 modes, but would suggest only doing so in Tripod / cinema mode. It's a sliding bar - so you can adjust up and down to get it to your needs. If like me and have shaky hands - the slightest shake on the sticks causes some blur, so adjusting the above settings helps as well as some mention getting longer sticks as they induce less movement than the short ones provided by DJI.
kenjiekun
