Phone connection question
Discussion in 'Mavic Pro Discussions' started by ThreeGs, Oct 20, 2016.
  1. ThreeGs
    ThreeGs Well-Known Member
    Oct 12, 2016
    139
    63
    Western MD (Wash Co)
    My previous experience with DJI products was the Phantom 3 Standard. I connected my phone to the controller's ad-hoc WiFi signal.
    All the Mavic videos so far appear to have the phone connected to the controller with a cable. The instructions that were up here for a little while didn't mention connecting to an ad-hoc WiFi network hosted by the controller. Is a wired connection the only way to connect up your phone/screen device?
  2. Advexure
    Advexure Well-Known Member
    Approved Vendor
    Oct 13, 2016
    412
    194
    Los Angeles, CA
    @ThreeGs for the most reliable connection and greatest range you do connect your device by wire to the Mavic Pro RC. The Mavic Pro can also be flown directly with with your device running the DJI GO App. This second control method is made possible by the Mavic creating a similar Ad-Hoc Wi-Fi Network to that you used with your P3 Standard. To enable the Wi-Fi Control Mode you simply flip a switch on the Mavic itself from RC to WiFi mode which creates this Ad-Hoc network.
    Hopefully that helps provide some greater insight and please don't hesitate to reach out if you have any further questions about this.
  3. ThreeGs
    Oct 12, 2016
    139
    63
    Thanks for the info, I do appreciate it, but I maybe wasn't making my question clear.
    I am simply talking about the phone's connection to the controller. Is it only via cable or can you connect the phone to the controller via wifi as well? To use the controller to fly but also see what the Mavic is filming I mean.
  4. Advexure
    Approved Vendor
    Oct 13, 2016
    412
    194
    Los Angeles, CA
    Reread your OP and apologize as I misread.
    The only way to connect your phone to the Mavic RC is by cable. You cannot connect to the RC by Wi-Fi, but as I described in my previous response, you can connect to the drone by Wi-Fi. Sorry for that misread. Hopefully that helps a bit more... :)
  5. ThreeGs
    Oct 12, 2016
    139
    63
    This confirms what I figured I was seeing. To fly with the controller and have a view screen a USB cable is required.
    Thanks again.
    Sent from my iPad using Tapatalk
  6. ThreeGs
    Oct 12, 2016
    139
    63
    I guess this is a very good thing because now my flight screen's WiFi won't be tied up with the controller connection and can instead try to connect to a nearby WiFi access point to get map data.
    NICE!
    Advexure likes this.
  7. Advexure
    Approved Vendor
    Oct 13, 2016
    412
    194
    Los Angeles, CA
    You are exactly correct. TU
Loading...
Similar Threads - Phone connection question Forum Date
Best controller to phone connection Mavic Pro Help Friday at 4:50 PM
New Samsung S8 Plus phone connection Off Topic Mar 28, 2017
RC to phone connection issues Mavic Pro Help Mar 25, 2017
iPhone connection issue Mavic Pro Discussions Mar 25, 2017
Phone or Tablet? Mavic Pro Discussions Yesterday at 10:12 AM
Share This Page
