Pittsburgh Pennsylvania saying hello
forsakenfilms
Pittsburgh, PA, USA
Just got my new Mavic 3 classic yesterday and out getting used to the new Rox remote and larger drone. This is my first video using the Mavic 3, be kind. I know it is not bracketed fully, I am coming from a photography/videography background, getting all the setting just right is a learning process. Started out with the mini 2 to make sure I would like drone photography and that I could control it.First drone video
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
Just got my new Mavic 3 classic yesterday Started out with the mini 2
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your M3 Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. But not the Mini 2
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Pennsylvania, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2 and the Mavic 3, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy Droning…
Welcome to the forum! :)
Suilven
