sonof40
Are these polarized? Or is there a separate PL?All of our Mavic filters have been updated and can be left on 100% of the time:
PolarPro | DJI Mavic Filters
Let me know if you have any questions on them!
-Jeff
-Jeff
Single filter special orders: [email protected]Does anyone just sell a single filter? I need one for snow, but everyone has filter packs for sale.
I'd actually like to try the DJI ones as they seem light and easiest to install, but shipping times are pretty long so I'm guessing they are not actually shipping yet.
I use the ND4 all the time, whenever shutter is natively at 1/240th which is generally under a cloudy sky, or during the golden hours, which is my favorite time to film
-Jeff
I have a, perhaps, dumb question. Aren't polarized filters best for bright, highly reflective environments (i.e. water, snow)? And in these cases you normally also want something like an ND32 filter. So why do you offer the polarized option on all but your ND32? Is it a technical limitation? Or am I just thinking about this wrong..?
Neutral, not natrual.
Well your shutter speed should be twice your frame rate while shooting video for example, your using 60 frames a second your shutter speed should be 1/120 of a sec. Just like Robert said. You can achieve theses while using N natural D dentistry filters.
And "density", not dentistry. LOL
Natural dentistry filters is a new homeopathic remedy. It's all the rage these days.
Do PLs have much effect on post production?
Also remember that a true polarizer has a filter factor usually between 1.25 and 2 stops (I'm going to take a spot meter to my polarpros and read the true filter factor). So a Pola/ND16 is equivalent or maybe slightly greater than a ND32.
You are correct that PL's are about a 1.5 stop reduction.
Our ND4/PL is the equivalent to and ND4, ND8/PL equivalent to an ND8 and so on,
Jeff
150$ for a set of filters? do you really spend your money like that? sorry.. I prefer to have, maybe, less quality video than spend 150$ for those filters...
Sent from my R7plusf using Tapatalk
in ur case.. ok.. you'll make money with those footage.. but for amatorial / hobbyist 150$ just for filters.. way too much! as u said probably some cheap but still ok filters will make it still acceptableYes actually that is how I spend my money. Been working and making a living in the motion picture industry for 28 years now and if I've learned anything it is your image is only as good as what it's passing through to get to the film (or these days sensor). Without ND filters on these fixed aperature cameras your footage will more often than not be unusable due to rolling shutter as opposed to less quality as you say.
Sure there are cheaper options out there and less expensive ones as well.
It is a matter of taste to a degree. Polarised for when you wish to reduce glare from reflections and to add more pop to clouds. But only when at or around a 90deg angle to the Sun. As for multi coated glass, this may help reduce internal glare from the filter itself which is always a good thing. I already have a set of standard ND's and a circular polariser. And now have on order a set of the Cinema Series polarised ND's.What is recommended then, PL or non-PL, multi-coat or non-multi-coat or is it a matter of taste?
