Purple fringing on 48mp stills fixed?
scro
UK
In the past the 48mp stills the Mini3P produced could have some purple fringing appear around high contrast items, particularly white. This doesn't seem to be typical chromatic abberation as it is not consistent across the frame, nor present in the 12mp stills, but rather appears to be a demosaicing issue. I don't have a lot of examples as I typically use the 12mp mode, but here is a snip from one I can find - see around the white window frames, or highlighted area in the leaves:
I recently took a couple of stills in 48mp mode and didn't see any purple abberations on any of them. I tried a few test shots (inside and props not spinning, as the weather outside isn't great) and taken snips of the most likely areas to get artefacts - see below. Is anyone else seeing similar results? I wonder if this issue was resolved in a recent firmware update?
boonaga
