1..Follow the safety guidelines of a community based organization.
This requirement for a recreation flight seems irrelevant to me if your not flying at a local field, yet it seems to be required for all flights.
Since no one has addressed this...
Yes, the FAA will now require all hobby flight to conform to guidelines of a COB. So even if you don't fly on COB managed property or even, you still need to follow some COB's guidelines.
Their is some mention of what a COB needs to be (and they they can submit their info to the FAA for approval) but, as far as I can see, the FAA is also stating that they will release more info on what a COB is.
This information is as follows:
‘‘(h) COMMUNITY-BASED ORGANIZATION DEFINED.—In this section, the term ‘community-based organization’ means a membership- based association entity that— ‘‘(1) is described in section 501(c)(3) of the Internal Revenue Code of 1986; ‘‘(2) is exempt from tax under section 501(a) of the Internal Revenue Code of 1986; ‘‘(3) the mission of which is demonstrably the furtherance of model aviation; ‘‘(4) provides a comprehensive set of safety guidelines for all aspects of model aviation addressing the assembly and operation of model aircraft and that emphasize safe aeromodelling operations within the national airspace system and the protection and safety of individuals and property on the ground, and may provide a comprehensive set of safety rules and programming for the operation of unmanned aircraft that have the advanced flight capabilities enabling active, sustained, and controlled navigation of the aircraft beyond visual line of sight of the operator; ‘‘(5) provides programming and support for any local charter organizations, affiliates, or clubs; and ‘‘(6) provides assistance and support in the development and operation of locally designated model aircraft flying sites. ‘‘(i) RECOGNITION OF COMMUNITY-BASED ORGANIZATIONS.—In collaboration with aeromodelling stakeholders, the Administrator shall publish an advisory circular within 180 days of the date of enactment of this section that identifies the criteria and process required for recognition of community-based organizations.’’. (b) TECHNICAL AND CONFORMING AMENDMENTS.— (1) TABLE OF CONTENTS.—The table of contents for chapter 448 of title 49, United States Code, as added by this Act, is further amended by adding at the end the following:
So yes... the FAA is _still_ being unclear on this and has _again_ failed to provide the needed information.
Setting that aside, this appears to be, yet again, BS fluff added into the law. It _still_ does not make any sense. As if the FAA cannot make up their own rules, you are still required to follow more rules by a COB.
