RTH Setup Checklist
AlanTheBeast
Montreal
I find myself repeating variations of the checklist below on the site again and again. Now I'll just link to this.
(2017-05-07 - REV 0.5).
RTH Checklist. Adjust to your local conditions.
  • Make sure your RTH settings take into account all obstacles in the area. Add 30 metres.
    • All heights are relative to your Home Point which is at 0.
    • I set them at the legal height limit. If need be, due to hills, towers, I'll set it higher.
  • Within the RTH settings it may be very wise to disable obstacle avoidance.
    • Because the drone may freeze in place facing the sun late in the day (early morning), so if RTH is radio link related, you won't be able to regain control.
  • Make sure your takeoff location has no obstacles overhead (branches, wires ...) for as wide a radius as possible.
    • Especially if Obstacle Avoidance is off in the RTH setting as recommended above as the drone will land directly below its current position if invoked within 20 m radius of the Home Point
    • If OA is on, then make sure there are no obstacles greater than 10 m height within 20 m radius of the Home Point.
    • If the drone is within 5 m radius of the Home Point, it will descend and land immediately
  • Do not start the motors until GPS has 12 satellites (10 maybe).
  • Fly straight up to 10m height. Wait 5 seconds there.
    • Good time to check gimbal pitch, exposure, focus and recording state.
    • Allows the cameras underneath to do their thing.
    • A good option is to use a landing pad. You probably own one:
      • A 70 x 70 cm piece of plywood is fine. Cut a handle into it too.
  • Never fly under bridges or other structures or trees since the first thing that happens when RTH engages is that the Mavic will fly upwards
  • You are more likely to have a radio link induced RTH if you fly
    • in cluttered areas (buildings - also a high WiFi "competition" area)
    • behind buildings, under bridges, into tunnels
    • You fly behind trees or rising terrain
    • You fly far (if you're far out you need to climb - be mindful of max height limits)
  • Fly upwind of your takeoff point.
    • To make sure your Mavic can get home in stronger winds
  • Cancelling RTH
    • Preferred: Depress and hold the RTH button - verify on screen that it has exited, or
    • On the GO App - hit the Red Cancel button and then confirm in the confirm dialog
Here is my Basic Preflight Checklist.
EDIT 0.5: Added basic checklist
EDIT 0.4: Correction to RTH within 20 m of Home Point; added "cancel RTH"
EDIT 0.3: added conditions that increase the likelihood of radio link failure
EDIT 0.2: Added obstacles in vicinity of the Home Point and flying under things.
EDIT 0.1: Clarity
NotSure
