Hi folks. Today, after my fifth flight, I removed my SD Card from my Mavic Air 2 (as I normally do), I plugged it into my Windows PC... and I've got this error message: "Warning: you need to format the disk in drive J: before you can use it".
I ran CHKDSK, and it said "Corruption was found while examining the boot region.". Full result at the end of the message.
I then tried CHKDSK /F (in Admin mode, of course), but it could not fix it: "An error occurred while examining the boot region."
The funny thing is that if I plug the SD in my Mavic Air 2, I can see pictures & videos, I can play them, I can download them on the connected iPhone... but the SD is not readable at all from my Windows PC.
Thankfully I've been able to recover all pictures & videos using a recovery software (Recuva): all files were there, in perfect shape. The tool was able to recover all of them in a snap.
But I am definitely concerned now. The SD is a brand new SandDisk Extreme 128Gb, v30 A2 Class 3. Now I will format it before each future flight, but I am afraid it could not be enough.
Any idea about a possible reason for this terrifying experience?
Bye!
A.-
P.S. below the result of CHKDSK:
C:\Users>chkdsk J:
The type of the file system is exFAT.
Windows found errors on the disk, but will not fix them
because disk checking was run without the /F (fix) parameter.
Windows is verifying files and folders...
File and folder verification is complete.
Windows has checked the file system and found problems.
Run CHKDSK with the /F (fix) option to correct these.
124864640 KB total disk space.
2804096 KB in 89 files.
1664 KB in 13 indexes.
0 KB in bad sectors.
256 KB in use by the system.
122058624 KB available on disk.
131072 bytes in each allocation unit.
975505 total allocation units on disk.
953583 allocation units available on disk.
Bye!
A.-
C:\Users>chkdsk J:
