some guy doing an FCC hack permanent for RC pro Controller
I waited 24hrs and still the hack told me to wait
If you have the same screen as below, i can tel you that the usb port is disconnected.
In that case look if your usb port is connected with the ADB interface. ( is controller usb port ).
Can i Help you remote??
I've done the hack now,it just wouldn't let me do the final part ,everything else went smoothly even deleting and pasting the new file ,
Now I finally have a fcc RC remote
I went through the whole process, getting "FCC patch installed successfully" message. Led off function works when I change the device name, but it still does not use FCC. What am I doing wrong? I believe this should be automatic, but even when I force it, the diagram still shows CE.
Are you copying the file from the SD card to the controller at the end of the process?
Yes, I did that, I replaced the file as the instruction says and it seems like the hack is working fine, because these shortcuts via the device name work, right?
Edit1:
Ok, I am a moron. There is step 15 in the instruction left. I will update this post if this succeeds.
Edit2:
I waited 2h, patched again, the message "FCC patch installed successfully" was seen, but still in Transmission tab it shows CE graph.
To be honest I dont know if the file you copy is for the whole patch or just the fcc part.
Looking at the first screenshot your in FCC mode
I saw that the firmware 01.03.1200 for DJI RC was released, does your mod still work? if so how to do it?
I downloaded the Version Jan 10 2024 02:18:41 and I want to upgrade my Patch. But It does not find the controller. Does someone know why? Im on FW .1000 at controller and FCC is active.
deepdark
