Sonar making clocking sound
kona
As I have a mild suspicion that my Mavic is a lemon (see this thread about my tilted horizon issue: Tilted horizon issue: tests with(out)gimbal cover) I was wondering if it's normal if the front sonar sensor emits a rapid clicking sound which can be best hear while the props are off and the drone is on? I localized the sound by holding my finger over the sensor and reducing the volume. The rear sonar sensor just behind it doesn't emit any sound. Same with you?
Front transmits, rear receives. Completely normal. On the upside, the fact that you can hear it means you must be younger, and your hearing hasn't degraded (yet).
Reactions: Kilrah
Yeah it's normal. The firmware took care of the tilted horizon as well.
Which firmware took care of which tilted horizon issue? The one where it's chronically tilted or the one where it's delayed in adjusting during roll?
Apollyon622
