Southern Idaho
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
So tell us something about yourself, do you have any drones, are you planning to buy a drone, what are your interests?
Inquiring Minds Want to Know…
Hello from the Crossroads of America terrydaz.
Welcome to the Forum. :cool:
Welcome to the forum! :)
Thanks everyone for the welcome, looks like I found some new friends I look forward to reading all of your posts. I have a Mavic mini and a Air2s it gets a little windy here some times and the Air2s does Fantastic in it. Mostly farmland here. I’ve been interested in flying ever since I was a kid with the rubber band wind up balsa wood planes “anyone remember those” I’ve only started drone flying for about a month.
Reactions: GFields and MA2 317
Thanks for getting back to us. Welcome again from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
In your part of the country, Idaho, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in Idaho, there are specific laws and rules for you to follow, please check to ensure these are current.
Below is the link to all of the downloads offered by DJI for the Mini and the Air 2S, including the User Manuals.
After you read the Manuals, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy, Safe and Legal Droning…
Greetings from Birmingham Alabama, welcome to the forum!
Saikiran Villa
