Splitting clips in LumaFusion
Kyle76
North Carolina
Can I edit out a portion of a clip and save that portion to the source folder under a different name? I have watched several editing tutorials, but I have not seen this covered. I sometimes make long videos with several different things that I might place in different places on the time line. Being able to split those clips up and identify them individually would be a big help.
You'd probably have been better asking that on the LumaFusion Forum
However, since I'm here - no you can't do it directly
Let's say you have a long clip and you split it into 4 parts
You can copy each clip to the clipboard and then paste that on its own to a new project
You can then export that project and give it a filename to identify it later
As long as you use the same fps and bitrate for your projects as the original you won't see a loss of quality
Reactions: Kyle76
kotszamana
