Yes, but also the drone needs to be in 30FPS mode, it won't work on high frame rates.Does the drone need to be airborne for subject scanning?
Thanks for the replyYes, but also the drone needs to be in 30FPS mode, it won't work on high frame rates.
You can also manually select the subject to active track it, you don't need to turn on subject scanning if you want.
