Will.i.am
- Joined
- Oct 12, 2016
- Messages
- 258
- Reactions
- 144
- Age
- 72
Once again, GPS can compute a track, not a heading. Without knowing which way the nose of the aircraft is pointing, how do you determine when it is "flying forward". Which stick movement do you use to make the Mavic "fly forward". Forward has no meaning to a quadcopter since it can fly "forward" in any orientation. If I fly the Mavic backwards due North, the GPS will compute a track of 0 degrees. The front of the aircraft is pointing 180. That is the heading. You keep saying that GPS can tell which way the drone is pointing and gives aircraft orientation - sorry but my 20 years in Naval aviation and 5 years as an instructor of aircraft navigation tell me that you are the one that is wrong.No, I'm sorry but you're wrong about it being "absolutely essential" in the case of drones. A compass failure on a drone would be an inconvenience but would not lead to any lost capabilities if GPS is still operational. Even without a working compass a drone can determine which way it is pointing by flying forward a few yards and noting in which direction it has moved according to its GPS readings. That gives the drone its orientation. No compass required. Admittedly, it's not as quick or perhaps as accurate as an instant reading from a working compass, but it is a perfectly viable fallback option in case of a compass failure.
Finally, even a working compass is of little use in determining aircraft orientation if one is at or near the magnetic North or South Pole. The GPS procedure I just described, however, would work even near the magnetic poles. So, no, a well designed drone should not have to go haywire in its navigational capabilities even if it is flying near one of the magnetic poles.
Every aircraft, including UAVs, needs a working compass to fly. The FAA requires it:
"Under VFR operation, part 91, § 91.205, requires a magnetic direction indicator (that is normally intended to be a compass) for heading information." A GPS does not fulfill this requirement.
