Trouble replacing landing gear leg (front) on Air2S-broke one LED wire
beeflyin
Florida
Trying to get out the LED light on the Air2S (still attached), the yellow wire is no longer attached. How to repair this?? I don't have a soldering iron, but would buy one if I knew what to get. Ugh. I need this drone this weekend, but don't want to fly it if its "dangerous" to be in the air.
Put it back on and use it, not dangerous at all.
Thanks!View attachment 174905
If you really need to get the bird up into the air, as a TEMPORARY fix, you could strip a little of the yellow insulation off the wire and then try welding the bared wire to the pad with a tiny blob of C/A glue (super-glue). C/A is conductive. But afterwards, you'll need to clean off the chemical weld and sort it out properly with a fine tip, variable temperature soldering iron.
Yes, I have done this. Field repair of a similar problem after my Mavic 2 dropped off the low slate wall it was resting on onto its front starboard antenna housing. I was on an uninhabited estuary island waiting for low tide to come round again.
My drone 'medic's' pouch. On my pack every time I head out.
bant18
