UK CE to FCC working
@MG10 no it does not. When you reboot a drone the hack is gone. You must every time apply hack if you want fcc.
Thanks droncek. One more doubt: the process for MA2 suggests using the bottom usb port in rc. Is this just to enable hack and then it must be connected to higher usb port, or it must be connected to the bottom one for fly?
Bottom usb is only for applying hack. Once applied you disconnect it, switch off DH Companion app and connect cable to upper usb like always.
Reactions: gogorokokoko
ErieSkyPixel
