Vero Beach, Florida
Hello from the Crossroads of America JohnKDelaney.
If you haven't done it yet, swing by and take the TRUST test to keep a copy with you when you fly.
It's a free no fail test that's easy to take.
Depending on what / how you are flying, it may need to be registered with the FAA.
Good luck and welcome to the Forum. :cool:
Welcome to the forum! :)
Just joined Mavic Pilots and looking forward to picking up some tips from some of you experienced pilots.
I saw in one of your other postings that you are flying the DJI Air 2S, the link to the User manual is below…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
boatdoc
