Waiting for this heat to let up for my first flight in TX!
Volar Solo
TX
Good evening!
New remote pilot here with mostly book and classroom instruction.
After studying relentlessly for the past 2 months and successfully applying for my Part 107 license, I finally pulled the trigger and purchased my first real drone. I am now the proud owner of a DJI Mini 3 Pro, and it is a HUGE upgrade from my previous experience with a little Tello drone from Ryze Tech.
As luck would have it my drone arrived in the middle of a brutal heat wave here in TX that has me grounded until further notice. Despite my excitement to get going as soon as possible, I've taken the time to prepare for my first flight by reading over the manual, testing hardware & equipment, making sure I have flight logs, registration paperwork, etc.
Not gonna lie, I feel like I have run out of stuff to prepare for... the itch to fly is getting hard to ignore, haha!!
I'm thinking of just getting up extra early before sunrise and heading down to the local park to get my first test flight out of the way before the heat can kick in. Who knows, after a little practice flying around the park, I might just be able to get a good shot of the southern sun rising over TX.
Wish me luck, y'all!
welcome to the forum
early morning and late evening are the best times to fly when its hot
Hello from the Crossroads of America Volar Solo.
That's the best time to fly for me.
Welcome to the Forum. :cool:
It's hard to ever run out of YouTube videos to watch for learning.
What is the temperature at your location? What is the max operating temperature for the Mini 3 Pro?
If temperature is within operating range, then enjoy flying and keeping the drone moving.
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
The Lowepro protactic utility bag 100 AW neatly fits the Mini 3, the controller (RC in my case), and some batteries. Not a hard case, but some padding against knocks — and can be attached to a belt as well as carried on the shoulder strap.
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
I'm guessing that you did in fact get your Part 107 License, so you know what you have to do…
Since you live in Texas, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
"Welcome to the forum from the outback of Australia. Look forward to your input on the forum.
How hot does it get in Texas?"
American South doesn't get all that hot. I remember once in 1952 seeing 44°C in eastern Arkansas, but 37°C is more typical during the summer.
SK farming
