Why is "Cloud Cover" a factor in decision to fly?
gjmphoto
New York
I use UAV Forecast and see cloud cover as a factor, independent of GPS Satellites locked. I'm wondering what the problem is regarding CC? If I have 15-18 satellites locked but 90-95% cc, why is that a problem? Is it just VLOS or is there something more regarding control of the drone?
In my country CC is not an issue if you keep below its floor level. Generally never a problem.
It will not cause a problem GPS-wise. The only thing the clouds will potentially do is make it hard for you to see your drone and/or other nearby aircraft.
Reactions: Ping^Spike
I love how the UAV Forecast app can lock on to 14.3 satellites.
WTF? :D
I think it has to do more with the ceiling than anything. I am only assuming as I have flown on mostly cloudy days but had great visibility.
Also, if you are flying to get good video, extensive cloud cover might make that a less desirable situation.
But all the parameters in UAV Forecast are user changeable, so it's just a matter of what YOUR threshold is.
Cloud height is way more useful than cloud cover.
UAV Forecast has lots of pointless things for no-fly. Cloud cover, K index and so on. Fortunately every single parameter is customisable.
SokmaN_cy
