2020 flight logs missing
  • Thread starter Thread starter Deleted member 133794
  • Start date Start date
D
Guest
Quick question.......i'm trying to look at some older flight data on assistant 2 but i can only
see flights for 2021 ......there aren't any listed for 2020 is this normal.
Can be normal ... that depends on how big the inbuilt memory is in the MA2 ... the onboard logs that you see in Assistant 2 (which aren't of any use to you as they are encrypted) are being overwritten on rolling basis when the memory is full.
If you want to actually use flight logs you have to get them from the mobile device you flew with ... check here on how to retrieve --> Mavic Flight Log Retrieval and Analysis Guide (read under section 3.)
great many thanks....i'll check it out
[ Smart Aleck remark ]. Don't know about you, but I have decided that 2020 never existed and have erased it from memory ;-). (wink)
wang
