2nd hand Mini 3 Pro remote ID broadcast
madkiwi
Florence MT
Buying a Mini 3 Pro from a guy who has been using it as a professional photographer so it has been individually registered under part 107.
Neither the seller nor myself want his info tracked when I am flying the drone.
So what steps do we need to take to get it completely unregistered? I am going to be flying it for purely recreational use.
Thanks
I think all he needs to do is go to his dashboard in the FAA registration portal and delete/remove his details. However, I am unsure of what you mean by "tracked" in the context of flying the drone, could you clarify? DJI drones are not currently being tracked by anyone under any circumstances (except by maybe the Chinese apparently). Arguably it is impossible to know who exactly is "behind the wheel" when a drone is up in the air. If the seller is concerned that if the new buyer might crash the drone, he might get a phone call from the authorities you should let him know his details are in a permanent government database and he is forever linked to that drone's serial number no matter what. ;)
Remote ID (RID) doesn't identify the pilot so no worries from an ordinary daily basis but I wouldn't be honest if I didn't mention it will always be possible to link him to that drone. He created that bond when he purchased and activated the drone.
As long as you DO NOT tape your wallet to your drone you wont be tracked lol.
The RID number your drone transmits is simply that- A number BUT now what they CAN do is prove you are a repeat offender and therefore deserving of the FAA's STEEEEP fines, simply by putting your RID number into a database. Unless you are smuggling narcotics or interfering with airport operations "THEY" are not watching you fly at Norad. lol ( at least thats what they tell me );)
Reactions: mavic3usa
I think I wasn't clear but you guys seem to have figured my intent- nobody wants some alphabet agency shooting his dog because I did something stupid with a drone he used to own but is still in the NSA database (before you chime in that it's the FAA nobody is naive enough to think the NSA doesn't take a peek).
I have no intention of doing anything other than fly recreationally so I won't be registering any drones under 250g. However the Mini 3 Pro broadcasts its ID all the time anyway, wish it didn't but that's the way it is.
If you don't register the drone then the RID number CANNOT be traced back to you. Its not like the drone somehow displays its purchase info. However the number will be displayed SO I suppose if they somehow took your drone read its RID number thru an application and then checked all rid numbers with violations I guess maybe they would know who you are and fine you. But I think thats more science fiction than fact. As long as you are not violating the law why would you care that your drone is basically pinging a number to the tower? RID info will not tell the IRS your true tax info nor will it inform the local authorities of your warrant for parking to long in a loading zone. so you are free to fly with RID without giving away any important data reveling who you are.
Reactions: Mrprop365
True but I still believe the jury is out on this. A drone that is broadcasting RID details but connects to nothing in the FAA database is likely suspicious. As you know, there are many versions of the truth and one of them says if you broadcast RID, you register it. Personally if it were me, I would register it myself before someone else does it for me (how's that for science fiction). :)
RID is very short range so unless they are following you and physically near you, you won't be "tracked".
Reactions: mb34928
FYI, for DJI drones the RID "number" is the manufacturer serial number of the drone.
Stale data in the FAA registration database when transferring ownership to someone else is a valid concern. This is easily corrected by deleting the registration. This has to be done anyway before the new owner can register.
Until I have some reason to believe the FAA is behaving in some underhanded way with all this, and I don't, I trust this procedure will protect me from suspicion should the drone be used for nefarious purposes in the future.
While people in the US government behave abusively from time to time, it's important to remember we don't live in Nazi Germany or Soviet Russia.
I believe that as of the latest update from DJ, as long as you're flying with the smaller battery it does not transmit RID
Only the Mini 3 and Mini 4 Pro... The 3 Pro transmits RID at all times, regardless of which battery is used.
Have I got this right? If I buy a used drone in the US, regardless of if it has been activated before, I will still be able to fly it recreationally? No deleting anything or worrying about some alphabet agency shooting my dog? (perfect description)
The previous owner is getting his information pinged and there is nothing for me or my dog to worry about?
Reactions: BroomRider
The question, & issue, I have, re: the difference between the Mini 3 Pro, vs the Mini 3 & the Mini 4 Pro, when it comes to the RID broadcast, is that neither the latter broadcast the RID when using the standard (<250gm battery, while the Mini 3 Pro does, & DJI never bothered to update the Mini 3 Pro software similarly.
Thankfully, my Mini 3 Pro got replaced under their extended flight assurance program (camera flaw, no crash), with from what they said, was an OEM pre-RID software, Mini 3 Pro.
They did make specific that I needed to update it to the current (post-RID) software before I flew it, which I won't be doing... At least, not until they give the same kind of software upgrade to the Mini 3 Pro, that they did for the other 2 I mentioned.
Unless & until they do the same for the Mini 3 Pro, that they did for the other 2, I'll be keeping that pre-RID software on my replacement Mini 3 Pro, ESPECIALLY since that can't be rolled back 1nce installed.
Thankfully, there are resources available online that I can use to roll back my RC controller software so it'll work with my pre-RID Mini 3 Pro.
I'm with the OP on this, considering that there are too many inconsistencies re: the FAA & its application of the regs, between the commercial vs recreational requirements - a commercial pilot needs to get their license even if they make a single penny, flying a 25gm micro-drone; it's all about the FAA demanding their cut of the commercial pilot's profits, you see, & has nothing to do with "safety" - & regardless the innocence &/ sensitivity of the RID info broadcast, even if it's my grandma's chocolate chip cookie recipe, I don't care to have it collected by any alphabet agency, regardless the benevolence of their excuse &/ intent.
On the concerns/dangers of possible abuses &/ exploitations of the RID signal, earlier this summer, there was someone who knew that I flew a drone, & stated their intent on using that to track my location, & within the context of applying lethal force against me - no, I never did or said anything to them to cause them to make that threat, & yes, everyone says to record any incidents, & to call the police if anything happens, but they'll only arrive after the fact, & despite my being a female in my mid-60s, I'd rather not have to explain the body & the blood.
But, both the location of the drone, & the controller, or at least, its launch point, can be tracked, amirite? 🧐
does mini 3 pro always when flying broadcasting remot ID? and mini4pro only with plus battery use?
Rolling Horizons
