3D Printed Accessory Holder for the Mavic 2 Pro Camera
Bob001
New Plymouth, ID
I recently purchased my Mavic 2 Pro and being an avid photographer, wanted to use filter elements with the Hasselblad camera, so I designed a slip on holder for them. I thought it might be a good project to share with Mavic users so I en-capsuled the project in a PDF file along with the needed stl files to print from. It's useful to read the PDF prior to using the 3D print files.
Hope members can make use of this.
Reactions: navegabem
Would you post a picture?
Reactions: _gonzales_
Photos are included in the PDF file. They show the holder and the storage case.
Additionally, I did some work testing the Hasselblad for infrared and it has little sensitivity for the IR range so I updated the PDF to reflect that (new set of files attached to this reply).
Additionally, I did some work testing the Hasselblad for infrared and it has little sensitivity for the IR range so I updated the PDF to reflect that.
Okay, thanks....I should have looked at the file.
GorillaP
