A few simple questions
How do you land?
  • Hand catch
  • RTH including landing
  • RTH + manual landing
  • Manual return to starting point + manual landing
  • Separate landing function
  • Other (do tell)
Results are only viewable after voting.
Earth
How should i place the antennas on the remote controller for best signal strenght, relative to the aircraft? What does RTH altitude mean? Meters above the ocean, meters above the point from which it took off? Isn´t it always best to hand catch drone when landing, since there often is grass or small particles that can get inside i i land on the ground? What is the fastest way to return to startingpoint, (presuming you can get the right direction manually), RTH, sport mode, other?
Hate to state the obvious but all of that is covered in the manual, which can be downloaded from the product page on DJI'S website.
Flat sides of antennas facing aircraft with antennas parallel to each other.
All heights are relative to your home point, which starts at zero.
I always hand catch to avoid obstacles and dirt on the ground, but it is a personal choice. Some use a landing pad.
Sport mode is the fastest way to travel but it also uses more battery power. I fly with OA off to get a speed between P and Sport mode without the higher stick sensitivity of Sport mode.
THANK YOU! Legend. My hero
I'm sorry, but if you won't even crack the manual to understand something as basic as what RTH altitude means, you need to add "Crater it into the ground" and "Get it stuck in a tree" to your poll options above.
give it time
Reactions: Mr. Salty
RobertCNewman
