Hey folks. I'm pretty much brand new to drone flying. Just prior to this crash, I had a successful video using Active Track. Not sure why this happened. One thing is, when I sent the drone up, I had intended to set the height of it to stay above the trees. Well, the ground level changed from where it set it's RTH spot by about 20'. But that shouldn't really matter, right? Regardless of what elevation you set the drone to fly at when using Active Track, it should still avoid obstacles, right?
When the drone got tangled up within the branches of the tree, I got out of the UTV and tried to fly the drone out of the tangle. It wouldn't let me fly it out with the sensors turned on. Also, I got a low battery warning, and I was worried that I'd run out of battery and crash to the ground. So, I put it into sport mode to circumvent the sensors, in an effort to get it out, and sure as (you know), I crashed the drone.
Did I do something wrong here, or was this possibly because the tree's branches weren't filled out very much with leaves yet, and the sensors couldn't pick up on the branches? I just mailed the drone back to DJI, and am waiting for my new one to get here. Hope I can avoid making the same mistakes again. Thanks for whatever input you guys.
