Hi,
I am using a DJI Mini 5 Pro and I flew a mission planned with Litchi (new version with KMZ). I do not understand why the drone stops for a long time at the discontinuity points of the flight plan. While reviewing the flight logs (with Phantomhelp), it almost seems as if the drone temporarily loses connection with the remote controller, even though it was flying quite close to it and the signal was always 100%. What is also confusing is that when analyzing the same flight data with AirData, these warnings or anomalies do not appear at all.
Do you have any suggestions or guidance on how to further investigate this issue?
Thank you.
Lithi Mission: Litchi Hub
Flight logs: DJI Flight Log Viewer - PhantomHelp.com
Thank you.
