Anticipated arrival
Thanev
Alberta,Canada
Really looking forward to the arrival of my flymore package. Any tips on packing the case? I wont be using the prop guards,but hope everything else fits neatly in the bag.Or do I need to get an aftermarket case?
Thanks
Reactions: Mrveronn
go to walmart and get a gym bag, 8X17....around 12.00, take cardboard and make a hard bottom
Reactions: Thanev
Hi Thanev,
The case neatly holds in its dedicated cutouts the MM, the charging hub (with the two spare batteries inserted in it), the remote controller, and one of the small cardboard boxes with the spare props. (I put the two unused controller cables and the two charging cables in this box as well, and put the box below the charging hub in the case's cutout).
I can also put the quick charger in the box next to the MM and the case closes easily without pressing on anything, so you don't need any aftermarket case in my opinion (Unless you want one which would also hold the propeller guards - but you wrote that you don't intend to use those).
I hope this helps.
Happy flying!
Las
Reactions: Thanev
Thanks
For me "fly more" case when I just go to the park and fly is too big, it is perfect when I travel but not when I go and fly. It is cold where I am so I keep 3 batteries on my body, remote on the inside pocket of my jacket and I got case just for the drone that can fit in outside jacket pocket. This makes me super mobile.
Reactions: netsonic
This is everything I need while travelling with the drone, maybe one extra USB cable to be able to charge everything over the night in the same time. That will also fit in the provided case.
Reactions: Thanev
gazzyfly
