Anybody could help me
Urko
Dear All,
I am new here. I bought a Mavic pro and last week I downloaded my first videos from the micro SD card. My surprise was that I see all of them in slow motion. Do you know why?
Best regards,
Urko
The 120FPS setting generally records in slow motion. If this is not acceptable, you can either speed it up using post processing tools (Like Final Cut, Adobe Premiere, Resolve, Filmora etc) or record at a slower frame rate.
Reactions: Urko
Dear All,
Check your camera settings to see what the shooting frame rate is.
If it's 60 fps or higher, drop that down between 24-30 fps.
Some people assume that bigger must be better but unless you have a particular reason to shoot 60 fps, avoid it.
Reactions: Urko
Thanks a lot to both for the quick answer. I will check at which fps is recording.
Regards,
Urko
Hi again,
Is strange because in the DJ1 Go4 application in the album the speed of the video is normal but in the micro sd card is at slow motion. Also attached you can see a picture without any postprocessing. Do you think the image quality is OK? Once a make zoom the picture is pixeled.
regards and thanks ,
Urko
It would be helpful if you posted your camera settings
Are you sure that your computer can handle it? Also check if you have the camera set for H265 because a lot of computers can't hang.
Jrwooley4
