Anyone else experiencing this? Weird variable frame rates.
eric32
Arizona
File Path: C:\Users\oatmeal\Desktop\TEST MAY 12\dji1620843142157.mp4
Type: MPEG Movie
File Size: 46.06 MB
Image Size: 1920 x 1088
Frame Rate: 24.06
Total Duration: 00:00:40:09
Pixel Aspect Ratio: 1.0
Alpha: None
Video Codec Type: MP4/MOV H.264 4:2:0
Variable Frame Rate Detected
Another File: Shot at the exact same specs.
File Path: C:\Users\oatmeal\Desktop\TEST MAY 12\dji1620843147116.mp4
Type: MPEG Movie
File Size: 37.16 MB
Frame Rate: 25.37
Total Duration: 00:00:31:21
Alpha: None
What the hell? Im shooting in 4k/30fps. How would this even happen? How would this file be 46mb shooting at 4k/30fps?
Dang. First it was getting noise out of this M2Z and now this. No wonder my footage looks like crap.
: 1
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=5
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 39 s 593 ms
Bit rate : 10.3 Mb/s
Width : 1 920 pixels
Height : 1 088 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 25.913 FPS
Minimum frame rate : 23.949 FPS
Maximum frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.190
Stream size : 48.5 MiB (100%)
Title : VideoHandle
Language : English
Encoded date : UTC 2021-05-12 17:44:58
Tagged date : UTC 2021-05-12 17:44:58
Codec configuration box : avcC
This info also came for MediaInfo
I was recording
4k.30FPS
100ISO
1/60 Shutter
ND16 Filter
All that was perfect exposure/etc
D-Cinelike
I didn't know it was recording the internal storage on the drone, I wanted it on the Internal Card, but it saved to the drone.
The photos I took are also somehow missing in action. So weird.
Select the SD card you insert into the drone. If that doesn’t work send it back to the retailer.
Totally, thanks. What Im wondering is why are the settings different because it was stored on the internal drive, VS the SD card that I thought I selected. That should change nothing. Thanks for the reply.
How are you getting the file onto the computer?
It looks like you may be looking at a cache file and not the original full sized video. That would make the most sense for this situation. If you were recording at 4k then the video should be in 4k which it isn’t here.
I experienced the same on the Action 4, the first video had a variable frame rate of 2.305 fps minimum and 29.970 fps maximum while all the following videos had the proper 29.970 fps (I didn't stop the recording between the videos, the videos automatically split after 16 GB filesize, so it was the same settings), so that doesn't seem to be Mavic specific, but DJI related. It happened with a relatively full SD card, but it was V30 rated as recommended (Samsung EVO A2 select 256 GB), and the last 3 videos that completely filled up the SD card had the proper framerate again, so I don't think it was an SD card problem, but I'm not sure about that, maybe the SD card was too slow as it was too full (50 GB free out of 256 GB)
kaidoestech
