Assistant 2 2.1.10?
IMADMAN
What is the current assistant 2 version for the mini?
I read something about 2.1.10 but can only find 2.0.10.
The 2.0.10 can detect the controller, but it doesn't detect the mini? Any help would greatly be appreciated.
2.0.10 is the one I loaded directly from the Dji site. When I go into the assistant 2 it doesn't detect the mini, it detects the micro sd card. It can also detect the controller but not the mini.
You must boot up Assistant, turn the mini on and connect to your PC wishing 20 seconds, it should then show up. Don’t forget the controller if your upgrading or down grading software
Tried that several times, but even doing it within the 20 seconds it doesn't recognize the mini. If I read it it correctly I do the mini first, then the controller after. I got the mini 2nd hand, right now the only issue is assistant 2 not seeing the mini. If the mini is on current firmware, and the controller is on older firmware would that make a difference?
Jiddles
