Asst2Version1.2.4 not revealing choices
hewo
Honolulu
Mavic Air 1 aircraft firmware below 01.00.0400 are permissible for flashing
But the versions below 01.00.0400 do not show
That means asst2V1.2.4 has been hot patched without knowing?
What does appear for selection is mere 01.00.0620 that is all
But way up at the top of the selectable area there's the current drone's firmware version shown but suffix'd with a negative symbol, the minus sign
In this case Grapevine's version sent is 01.00.0300-
The only choices are two then. Upgrade into 01.00.0620 or factory default which resorts to 01.00.0300 however if chosen and executed, the minus sign will be gone for status shown. Is the minus status indicating Grapevine's burn status last made?
And why aren't the other fw versions historically shown like before the alleged asst2 being hot patched?
Leonardobusss
