you mean the option in the photo settings - it gets back to ON by itself? odd. try to reset gimbal settings to default, may be, and see again. it should not ever flip on its own initiative. unless you have also other programs other than go4 - litchi, etc. that may set those values as they see fit.
You must be using android. It s a problem with any android version of the DJIGO4 app. It should work as stated on iOS.
Crystalsky does it SC does it. Etc.
What you have to do is keep turning it off via the slider. After a certain number of attempts it will finally stay off and you can have just AF/MF. ONCE you get it to stay off try not to turn it back on as it will take the same number of attempts.
I have gone back to DJI several times but they appear clueless on it.
Always surprises me that more folks don’t notice this issue. I guess most people just use AFC. Which I never want.
Paul C.
No it stays off for me and i use android.....but i have the zoom?You must be using android. It s a problem with any android version of the DJIGO4 app. It should work as stated on iOS.
Paul C.
No it stays off for me and i use android.....but i have the zoom[emoji2369]
