Battery Charging Issue with Power Station
bkushner
USA
Having an issue with a new power station. When I plug in the USBC 65W port to the DJI AIr 3 Charging Hub the unit shows it being charged and not the battery. Anyone else know how to fix this?
You'll have to be more specific. What "new power station?" What "USB C 65W port" are you plugging into the DJI Air 3 Charging Hub? What "unit" shows it is being charged instead of the battery? Is the battery properly plugged in and secured within the Charging Hub? Does the Hub properly charge the battery when a DJI branded 65W charger is plugged into it, say from a Mavic 3, if you still have one?
Yes when I plug into the charging hub with a battery it begins charging the power station. The port is an in/out port. Don't have a mavic 3. Works fine with the Mini 4 hub.
i don't have an Air 3 hub to know its unique quirks, but it is different than the Mavic 3 hub, because of the ability to charge one battery in the hub from the remaining power in the other two batteries. Maybe that is what is tripping it up. Sounds like the power station is turning on the Air 3 battery and attempting to discharge it as though the power station is another Air 3 battery.
Is the power station actually turning on the Air 3 battery in the hub, without you turning the Air 3 battery on?
Have you tried using the power station to charge the Air 3 battery inside the drone? That will likely work, as the hub features are likely confusing the power station.
I've only had this happen once, but it was a failing battery. This was fir a Magic 2 Pro. The battery was dormant for a couple months and then didn't charge although the charger showed it was.
Hopefully not your issue!
The Air 3 Charging Hub can also act as a power bank so the charging protocols between the hub and power station are prioritizing the hub as the power source. You'll need a power station with a dedicated (non in/out) USB-C charging port.
I figured that might be the case.
Yes too slow. I can use the 12volt adapter ao
I’m good. Thanks.
I had the same issue you describe. I just saw this hub on Amazon - ordered and getting in couple days. Will let you know if it solves my issues. See you have power bank already - I just ordered an inexpensive one to throw in backpack at same time.
This set up works perfectly, just got and tested the new charging hub mentioned above with the new power bank. Charging from the power bank to the A3 battery @ 85w. A3 battery went from 61% to 75% in just a few minutes of testing.
I also tried using this same power bank with the original DJI charging hub, and same result as last time - charge was flowing in reverse, from the A3 battery back to the power bank (not what I wanted).
I bought Anker 735 Prime 20,000mAh. The product runs out of power before charging a 5,000mAh battery once.
mAh will not necessarily reflect the capacity of a battery unless the relevant voltages are the same. It is best to convert to Watt-Hours to truly understand energy capacity. Also batteries are not 100% efficient in that their stated capacities will not equal real world performance due to many factors such as resistance. I would estimate your Anker battery effective capacity as:
20,000mAh x 3.7V x 80% efficiency = 59.2 Watt-Hours.
The Mavic Air 3 battery capacity is:
4,241 mAh x 14.76V = 62.6 Watt-Hours
Your Anker battery does not have enough capacity to charge 1 Air 3 battery. Also, if your Anker power bank does not meet the PD 3.0 spec then it will be an extremely slow charge.
Thank you. No one, including the company, could make this good statement. I returned the product.
BuzoLibre
