Battery Charging Time
Bredi92
Hey,
So i bought the new AIR3 Fly More Package and tried to charge all batteries in the battery charger.
It took about 24 hours to charge 2/3!! batteries.
I tried multiple cables and different power supplies but it's still awful slow.
Which power supply and which cable are you guys using ?
Thanks!
you will need a PD charger with a minimum 65w output ,i use the DJI 100w which has two type C outlets and it will charge one battery in about an hour the cable that comes with the flymore plus another cable that came with the charger both of them work
Okay thank you very much! I ordered one and will try .
Where are the times gone where you bought something and there was everything you need included :).
Not sure where you are located BUT Walmart has a really good 65W PD charger-- cheap-- It is their Onn brand and I just got one for 20 Bucks !!!!! Works just like it should.
Reactions: Bredi92
edwin2588
