Battery charging....
WDKZoom
Mesquite, Nevada
I can't find it to re read it again but I thought I read somewhere that you are not suppose to charge your batteries on the multi charger and at the same time as the remote supplied in the fly more kit which it is capable of doing....any merit to this??
WDK
I thought I read that the remote control or the connection would get too hot......before I read this, I had already charged that way more than a few times with no problems.2AA0F18B-4062-4782-A196-BC00008F8569.jpeg
I can't find it to re read it again but I thought I read somewhere that you are not suppose to charge your batteries on multi charger and at the same time the remote that the fly more kit is capable of doing....any merit to this??
WDK
I think maybe you are referring to the initial charge of the new MA2 batterie. There was an issue that on the INITIAL charge some ppl where getting battery faults and the fix was to charge each one indivually. Since then I have noted on my MA2 a battery firmware update so I dont know if its still an issue.
......thanks.....I did not get a fault on my initial charge doing it this way. After I read that I thought I had messed up. Perhaps I was just lucky but the way the picture shows you don’t see anything wrong with the way I am charging?.....I usually have the third battery charging as well but it’s not in the rotation.
WDK
osje
