Battery dead
imMike507
Panama
I need help... my drone's battery was working. I didn't charge it and it was at 0, now it doesn't charge. What could have happened? Can it be saved?
Might be helpful to know some time frames for what you describe.
Battery sat unused for some duration of time?
Was working fine one day and dead the next?
Yes, was fine 3 weeks ago today I charge two on the battery charger hub, one charged at 100% the other don’t blink IMG_0136.jpeg
Dji multi chargers generally charge batteries sequentially, did you wait for the first battery to be fully charged before deciding that the second battery was dead ?
How empty was the dead battery ?
Yes, when I charge one 100% the other didn't start blinking and the charger light is red
How empty was the battery when you finished using it the last time ? If you do not remember look in the CSV of the flight log. The phantomhep CSV lists the battery serial numbers. Or you can, I think, get that information straight off the airdata webpage if you upload the log to airdata.
Have you visually checked the connector plug on the battery? It is possible for debris to get packed into the rebates.
But if you managed to run the battery down past the pre-programmed lowest limit set by the battery management board chip: the battery will have effectively bricked itself as a safety measure.
Contact DJI customer service and open a ticket concerning a faulty battery.
gauravsaxena
