Battery discharge device
Thanev
Alberta,Canada
Is anyone aware of the pinout on the Mini battery?
I would like to develop a discharge harness using a small automotive light bulb and a battery level alarm.
I have built one for my rc aircraft batteries and it works great.
i have one that i use for my three cell batts for my older drones and the batteries for my MPP i was thinking of getting and old USB cable and soldering it to the input and then i can put one battery at a time in the hub and discharge it using the bulb as i do with the others you should be able to get the info you need off the net as thats what i will have to do
Reactions: Thanev
I can’t speak for the mini as I don’t own one, but the pin out for the Mavic 1 is on the backside of the charger and car charger. See photo.
You could turn on the battery and check pins with a multimeter.
Could you be so kind as to provide a pin out diagram to answer the OP’s question?
Check the battery mod thread.
The connector pinout is
Data - + + - data
Data - + + - data
Thanks. That makes sense. Just scaled down version of Mavic Pro connector.
Now we know.
Reactions: Thanev
I sacrificed one of the battery plugs from my Yx charger to connect to my discharger. I could have just made an adapter but didn't have the connectors.
Good setup. I have a similar one for my Mavic Air. Smart discharger.jpg The discharger is a handy tool and will drain battery to storage level fast and consistently. ISDT Discharger . Not ready to sacrifice a Yx charger cable, yet, as I am looking for a MM battery cable that I can solder to the XT60 plug for the discharger. Enjoy your flying.
nikt_elo
