Battery firmware update
Torflyer
Toronto, Canada
Since I have got my Mavic mini I have never been prompted to update my battery firmware. I am up-to-date on all of my other updates. Has anybody else experienced this
Reactions: old man mavic
how many batteries do you have
I have three batteries
when you do a firmware update the battery that is in the drone gets updated at the same time ,then the next battery you insert will give you a message battery update available and ask you to do it you need everything to be turned on and connected up as if you were going to fly ,then afterwards do the same for the third battery
Thanks for the reply. I wonder why this didn’t happen with the previous firmware update that I loaded.
It would be because there were no changes to the battery firmware in the last update. Battery firmware updates don't happen very often.
.200 updated batteries, .300 did not, last .400 updated them again. if you swap the battery and re-connect to the dji assistant it will show you 'update' request if it needs to be done.
KRV
