BATTERY LIFE ON KARMA DRONE?
Hi again there Adam :cool:
I sincerely urge you to put that second hand KARMA out of the possible alternatives to get airborne ...
The model were launched 2016 & was stopped due to batteries falling out & a bunch of other MAJOR flaws. They re-launched it again 2017 ... but hadn't done anything besides fixing that the batteries didn't fall out in the air. By then the Mavic series had been launched & the KARMA was light years after & wasn't even close to be able to compete... & GoPro gave up.
Don't put your money on the KARMA ... you could equally just burn them up, it's that bad. Save a bit more instead, & go for a Mavic of your choice (new or second hand) ... you will be much better started up in that way, just happy flying without the monstrous disappointments you will have with the KARMA.
By the way ... the real life battery times usually was like 11-12 minutes.
Here you have the same vid about the flawed KARMA as we showed you in your other thread ... recommend you to check it out again.
Don’t buy a Karma. You may as well buy a brick and glue a camera to it.
Adam have you looked on our sister forum that's dedicated to the GoPro aircraft?
Nooo - don‘t do it, Adam. Don’t look! Abort. Abort. Abort! Stick with Mavics. ?
pyrotechnik73
