Cable issue?
Janl
Hi, I have sometimes problem to connect the Samsung S7 to the Mavic when I use the controller. Is it a cable issue or a app problem?
Tips?
This has been covered multiples times, search the forum, you will find all you need to know.
Tips?
Pick up a plastic thin whatever and clean your USB port up. Make sure the USB plug goes all the way in!
Reactions: Janl
Take away the little sliding frame that holds the phone's side of the cable so you get it hanging loose. Makes plugging in a lot easier.
GLobus55
