Calibration Help
The-Hive
England
Hi Guys, Just a quick question or two. How often should you do a compass, gyro and IMU calibration? and does it need doing when the drone in new and has never been flown before?
Thanks ...... Rod
Almost never.
Compass calibration is only needed if you add or remove accessories.
IMU (which includes the gyro sensor) should be done if you have a bad crash.
For a new drone out f the box, no calibrating is necessary.
Reactions: EricJT and The-Hive
You will find differing views on this subject.
Post number two is correct advice.
Reactions: The-Hive
Almost never.
Thank you @metalheadz
SerenaKuvalis
