It's not possible to tell anything from the tiny piece that you've cropped out of one of your photos.Could anyone tell me why my photos are showing lines across, particularly on roof and ground. Example attached. Thank you.
That's better, but the problem you are asking about, is that you aren't looking at a full-size image.Sorry, hopefully this will be better
https://www.dropbox.com/scl/fi/uyuyt6xz2m1y3x1wiotj8/Photo-05-05-2024-12-46-06.jpg?rlkey=2oe7zf36t9xzpc3a1j9pl6wn5&dl=0
I should have known, thank you very much.That's better, but the problem you are asking about, is that you aren't looking at a full-size image.
It's only 960 x 544..
Pull the SD card from the drone, put it in an adaptor and put that in your computer to copy the files across.
The actual full-size images should look a lot better than that.
Thank you, problem now solvedLooks like the lines from the tractor. You are at a different angle and they look different due to that maybe.
