Camera Settings
luke78
Hi all, I've only had my Mavic Pro for about 4 weeks, just wanted to get recommendations on settings you have saved for footage and Pics. Do you guys use auto or do you change setting depending on the target?
I only shoot in manual, I try and keep the same settings for each shot.....ISO =100.....shutter =50....custom white balance 5700k and shoot in art mode. To keep within the 100/50 you would need some ND filters. Best advise is go out and practice with the drone, play with the settings and compare the results.
Reactions: deleted member 877
Hi Mavic 2 Pilots
Paradise from Australia a new member
I have just bought a set of PGYTECH 8,16,32 & 64 filters and I’m not sure if I have done the right thing or should I have bought a Polarized filter only.
I am trying to eliminate reflection as I have the drone set on Auto till I become more experienced then I will use manual
Any advice would be appreciated
Hi Mavic 2 Pilots
Polarized filters are probably the best ND8PL, ND16PL is what I mainly use?
Located Brisbane, Queensland, Australia
matthewlogan
